Le 737MAX dangereux...!!??
Re: Le 737MAX dangereux...!!??
Ivoire06 a écrit : ↑lun. 6 janv. 2020, 11:37 Un nouveau problème...
Cette fois sur le câblage..la FAA enquête pour savoir si il faut prévoir des changements
The New York Times reported Boeing is reviewing whether two bundles of wiring are too close together, which could lead to a short circuit and potentially result in a crash if pilots did not respond appropriately.
A lire: https://www.reuters.com/article/us-boei ... SKBN1Z40U9
Je lis aussi:
The FAA flagged the wiring issue as potentially “catastrophic.” It is possible other protections like shielding, insulation and circuit breakers could prevent the short circuit, a company official said.
trittia
Message par trittia »
U.S. lawmakers fault FAA, Boeing for deadly 737 Max crashes
WASHINGTON/SEATTLE (Reuters) - A U.S. House investigative report into two fatal Lion Air and Ethiopian Airlines crashes on a Boeing 737 MAX faulted the Federal Aviation Administration’s (FAA) approval of the plane and Boeing’s design failures, saying the flights were “doomed.”
Article: reuters.com
Et le congrès y va sans détours
le MAX est un avion « fondamentalement défectueux et dangereux »,
https://www.air-journal.fr/2020-03-07-m ... 18716.html
